December 18, 2025Maintenance & Prevention
Understanding RV towing services
An image shot from below of a tall bridge with a gray sky above it
GS
Good Sam
“RV towing is required during mechanical failures, tire emergencies when a spare won't resolve the issue, and more. Towing an RV, however, often requires a professional with the right equipment and knowledge to ensure the RV is towed safely and securely. ”
Hitting the road in an RV is all about adventure and independence. You bring your home with you, making it easy to explore scenic routes, quiet campgrounds, and spontaneous detours. But with that freedom comes the risk of unexpected hiccups such as mechanical breakdowns, tire blowouts, or getting stuck far from help. That’s where understanding your towing options becomes essential.
Having a roadside assistance plan that includes towing services - like Good Sam - can help you avoid unexpected expenses and delays. Unlike regular breakdowns, RVs require specialized equipment and experienced operators. Knowing how RV towing works helps you handle emergencies confidently and get back to enjoying your journey.
When Do You Need RV Towing Services?
RV towing services handle everything from small travel trailers to massive Class A motorhomes. You should consider calling for professional help in these situations:
  • Mechanical Failures: Engine problems, transmission issues, brake system failures, or cooling system breakdowns that make driving unsafe.
  • Tire Emergencies: Blowouts, multiple flat tires, or tire damage in areas where safe roadside changes aren't possible.
  • Getting Stuck: Whether you're stuck in mud, sand, snow, or off-road situations requiring specialized winching equipment.
  • Electrical System Failures: Dead batteries, slide-out malfunctions, or generator issues that prevent safe operation.
  • Accident Damage: Collision damage requiring immediate removal from traffic areas or making your RV unsafe to drive.
  • Weather-Related Issues: Storm damage, flooding, or severe weather conditions making travel dangerous.
Understanding when to call for professional RV towing services versus attempting DIY solutions ensures your safety and prevents additional damage.
Can You Tow an RV Yourself?
While technically possible, towing an RV yourself can be risky and often inadvisable. RV towing requires specialized knowledge, proper equipment, and experience that most RV owners don't possess.
Professional towing methods include:
  • Flatbed Transport: Safest option for large motorhomes and damaged RVs.
  • Wheel-Lift Towing: Common for smaller trailers but requires careful weight distribution.
  • Heavy-Duty Recovery: Required for large Class A motorhomes and complex extractions.
Before attempting DIY towing, verify:
  • Your vehicle's GVWR (Gross Vehicle Weight Rating) can handle the RV's weight.
  • Compliance with state towing laws and safety regulations.
  • Proper equipment, including brake controllers and safety chains.
  • Insurance coverage for potential damage.
Your vehicle's GVWR information appears on a sticker inside the driver's side door frame. This represents the maximum safe operating weight, including passengers, cargo, and trailer tongue weight. Exceeding these limits can cause brake failure and dangerous handling.
Step-by-Step: How To Request RV Towing
If you find yourself stranded, here’s what the typical process looks like for requesting RV towing service:
Identify Your Coverage Provider
Know who to call – your RV roadside assistance provider, auto insurance company, or membership service. Having this information readily available ensures a quick response.
Gather Essential Information
Collect your membership details, RV specifications (length, weight, type), exact location, and problem description. GPS coordinates help in remote areas.
Contact the Emergency Hotline
Call your provider's 24/7 number with your membership information, RV details, location, and problem description ready.
With Good Sam, members can call 24/7 for immediate assistance across the U.S., Canada, Mexico, Puerto Rico, and the U.S. Virgin Islands.
Describe Your Situation Clearly
Explain what's wrong, your exact location using landmarks, any safety concerns, and whether you need immediate assistance. More details help the response team prepare properly.
Receive Service Confirmation
You'll get confirmation plus an estimated arrival time. Urban areas typically see faster response times due to provider availability as compared to rural areas.
Wait Safely for Assistance
Position your RV safely off the roadway, activate hazard lights, set up reflective triangles, and stay inside unless immediate danger exists.
What To Expect During RV Towing Service
Once the tow truck arrives, you can expect a series of safety checks and procedures. Here’s what typically happens:
  • Verification Process: They'll check your license and membership information.
  • Situation Assessment: Evaluate your RV's condition and determine the safest towing method.
  • Equipment Setup: Match specialized equipment to your RV's size and weight requirements.
  • Safe Transport: Secure and transport your RV to the nearest qualified service center.
  • Documentation: Complete the paperwork and receive information about the next steps.
How Much Does RV Towing Typically Cost?
Understanding RV towing costs helps you budget for emergencies. RV towing by a professional service provider can cost between $135-$150 an hour. The cost to tow a camper, RV, or big rig typically ranges from $4 to $7 per mile.
Factors that affect pricing:
  • Distance: Most services charge per mile, with rates varying by RV type and local market conditions.
  • RV Size and Weight: Larger RVs require specialized equipment and experienced operators.
  • Location: Urban areas offer competitive pricing, while remote locations command premium rates.
  • Time Factors: After-hours service often includes surcharges above standard rates. Weekend and holiday rates often include 25-50% surcharges.
Because these costs can add up quickly, it’s often smarter and more affordable to have a roadside assistance membership in place. Plans like Good Sam Roadside Assistance offer unlimited towing to the nearest service center without added charges, which can be a major relief when the unexpected happens on the road.
How To Prepare for RV Towing Emergencies
Having a few essentials on hand can make a huge difference during a breakdown. Here’s what to prepare in advance:
Essential Information:
  • RV specifications, including GVWR, length, and modifications.
  • Insurance and registration documents.
  • Roadside assistance membership details.
  • Emergency contacts for family and pets.
Emergency Supply Kit:
  • Reflective triangles for visibility.
  • First aid kit and flashlights.
  • Phone charging equipment.
  • Water, snacks, and medications.
  • Warm clothing for unexpected situations.
Safety During Breakdowns:
  • Move completely off the roadway and activate hazard lights.
  • Set up warning triangles behind your RV.
  • Stay inside unless immediate danger exists.
  • Provide precise location using GPS or landmarks.
RV Towing vs. Roadside Assistance – What's the Difference?
While often used interchangeably, RV towing and roadside assistance serve different functions. Here's a quick breakdown:
RV towing services handle transportation when your RV cannot be repaired on-site – major mechanical failures, accident damage, or situations requiring shop facilities.
Roadside Assistance provides on-site solutions:
  • Tire changes and emergency tire delivery.
  • Battery jump-starts and replacement.
  • Emergency fuel delivery.
  • Lockout assistance.
  • Mobile mechanic services.
  • Winching for stuck vehicles.
Some plans combine both services, offering unlimited distance towing plus certified RV technicians. Compare comprehensive coverage options to find the right plan for your travel style. Family coverage typically includes spouses and children at no extra cost, while some competitors charge additional fees per driver.
Many providers offer complete roadside assistance plans that combine both towing and on-site repair services for maximum convenience.
Pro Tips To Avoid Needing a Tow in the First Place
Prevention is always better than reaction. Use these expert-backed strategies to minimize your chances of needing a tow:
Regular Maintenance:
  • Check tire pressure and condition before every trip.
  • Monitor engine coolant, oil, and belts monthly.
  • Service brakes and axles per manufacturer schedules.
  • Test electrical systems regularly.
Weight Management: Stay within GVWR limits to prevent axle stress and brake failure. Distribute weight evenly and consider weighing your loaded RV periodically.
Route Planning: Use RV-specific GPS systems to avoid height restrictions, weight limits, and challenging routes. Popular navigation tools include RV LIFE and Garmin RV GPS.
Prevention Strategies:
  • Monitor engine temperature on long grades.
  • Plan fuel stops in remote areas.
  • Conduct daily inspections for tire condition and leaks.
  • Secure slide-outs and awnings before travel.
Drive Confidently with RV Towing Knowledge
Understanding RV towing services provides peace of mind for confident travel. Knowing the process, costs, and coverage options helps you make informed decisions during emergencies. Proper preparation and quality coverage make the difference between a minor inconvenience and a trip-ending crisis.
The next time you hit the road, don't just hope for the best—be prepared for anything. With proper knowledge and coverage, you can focus on creating memories, knowing professional help is available when needed.
FAQs
1. Can I tow my RV with any truck?
A: No, your towing vehicle must match your RV's weight requirements. Verify manufacturer specifications and comply with state laws regarding brake controllers and safety equipment.
2. Do RV towing companies operate 24/7?
A: Most offer 24/7 service, but response times vary. Urban areas typically see faster responses, while remote locations may experience longer wait times.
3. Will they tow my RV anywhere I want?
A: Most providers tow to the nearest qualified repair facility. Some plans may include destination options within coverage limits.
4. Is RV towing covered by Good Sam?
A: Good Sam, as an established roadside assistance provider, offers different levels of coverage, and their plans include towing benefits for various vehicle types, including both motorized and towable RVs.
RV Towing Services: What To Expect & How It Works
