December 8, 2025Maintenance & Prevention
Fifth wheel towing: What you need to know about roadside assistance
Close up image of an RV tail light on the side of the road with mountains ahead.
GS
Good Sam
“Roadside assistance for a fifth wheel RV offers many of the services as standard roadside assistance plans like towing, battery jump-starts, and lockout services. However, the size and weight of fifth wheels adds unique complexities that require a service like Good Sam that has the knowledge and expertise to help.”
Towing a fifth wheel isn’t like hauling a small trailer or popping the hood on a compact sedan. These large, luxurious RVs bring the comforts of home on the road, but they also come with some pretty hefty responsibilities.
When something goes wrong mid-trip, it’s not just inconvenient - it can bring your whole adventure to a grinding halt. That’s where specialized roadside assistance for fifth wheels becomes essential.
In this guide, we’ll break down everything you need to know about fifth wheel roadside assistance. From common breakdowns to choosing the right plan, we’ll help you stay ready for whatever the road throws your way.
What Is Fifth Wheel Roadside Assistance?
Roadside assistance for a fifth wheel RV isn’t the same as what you’d get for a typical car or even a smaller RV. While there’s some overlap, like towing, battery jump-starts, and lockout services, the size, weight, and complexity of fifth wheels raise the stakes significantly.
Imagine getting a flat tire on a rural highway. Standard car roadside assistance likely won’t send a heavy-duty tow truck or a technician trained to handle RV-specific hitch systems. That can mean longer delays, added stress, and, sometimes, out-of-pocket expenses.
On the other hand, fifth wheel roadside assistance typically covers:
  • Towing to a qualified repair facility (not just the closest one, but one capable of handling bigger RVs).
  • Flat tire changes or tire delivery if you don’t have a spare.
  • Battery boosts for your tow vehicle.
  • Lockout assistance for your truck or trailer.
  • Fuel delivery in case you run out of gas.
  • Winching or extraction if you’re stuck in mud, sand, or snow.
The biggest difference setting fifth wheel roadside assistance apart? These plans account for your RV’s size, your towing setup, and the need for specially trained service providers. And let’s be honest, when you’re stranded with a 40-foot rig, experience makes all the difference.
Common Roadside Problems Fifth Wheel Owners Face
When you tow a fifth wheel, you’re managing a lot more than just your truck. There are several points where things can go wrong.
Here are some of the most common roadside issues fifth wheel owners face:
1. Tire Blowouts
Fifth wheels are heavy, especially when fully loaded, making tire blowouts one of the most frequent (and dangerous) issues on the road. A blowout at highway speeds can cause serious damage to your trailer’s sidewalls or fenders.
Prevention Tip: Check tire pressure before every trip and keep an eye on tire age. Don’t wait for visible wear; replace tires as needed.
2. Hitch Problems
The hitch system for a fifth wheel is complex and unique. If the kingpin isn’t locked correctly or the jaws fail to engage, your trailer could disconnect – an extremely rare but serious risk. Even minor hitch alignment issues can leave you stuck.
Prevention Tip: Always double-check the locking mechanism and kingpin connection. Use a pre-trip checklist so you don’t miss any important steps.
3. Brake or Electrical Failures
Problems with the trailer’s brakes or lights can make towing unsafe and, in some states, illegal. Corrosion, poor connections, or blown fuses are often the culprits.
Prevention Tip: Include electrical checks in your routine maintenance and pre-trip checklist. Carry spare fuses and learn the basics of troubleshooting.
4. Weight and Balance Issues
An improperly loaded trailer can lead to swaying, uneven tire wear, and excessive strain on your tow vehicle. Poor weight distribution increases the risk of mechanical failure or loss of control.
Prevention Tip: Know your fifth wheel’s GVWR (Gross Vehicle Weight Rating) and use a tongue weight scale if needed. Keep weight balanced and secure, as exceeding the GVWR can lead to blown tires, strained brakes, or even frame damage.
With solid preparation and regular maintenance, many of these issues can be avoided. But when something does go wrong, having a roadside assistance team that understands the unique needs of your RV makes all the difference.
Choosing the Right Roadside Assistance Plan for Your Fifth Wheel
These larger trailers have unique requirements, and a standard auto plan often won’t cut it. Here’s what to keep in mind when comparing options:
1. Coverage That Fits Your Rig
Always read the fine print. Does the plan explicitly cover fifth wheel towing? Many auto roadside assistance plans exclude trailers that exceed certain size or weight limits.
Look for RV-focused plans that offer:
  • Towing for both your tow vehicle and fifth wheel.
  • Transparent mileage caps or long-haul towing restrictions.
  • Coverage that includes remote areas or cross-country travel.
For side-by-side comparison, you can check out Good Sam’s RV roadside assistance plans to see how different plans stack up.
2. Know Your Specs
You should know your trailer’s weight, length, and configuration in addition to the year, make, and model. Roadside assistance providers need these details to send the right equipment and technician to assist you. If your plan doesn’t account for your trailer’s specs, you might be stuck waiting for a second (and better-equipped) tow truck.
3. Service Provider Network
A roadside assistance plan is only as reliable as its service network. Look for providers that offer 24/7 support and work with RV-trained techs who know how to handle fifth wheels safely and efficiently.
4. Added Perks
Some plans offer extras that are especially useful for fifth wheel travelers, such as:
  • Trip interruption coverage if a breakdown interrupts your journey.
  • Mobile mechanic dispatch.
  • Emergency fuel or propane delivery.
The bottom line is the more RV-specific the plan, the more peace of mind you’ll have on the road.
Getting Ready for a Roadside Emergency
While you can’t always predict when things will go wrong, you can plan how prepared you are when they do. Here’s how to set yourself up before hitting the road:
Follow a Pre-Trip Checklist
Make these checks a part of your routine before every drive:
  • Check tire pressure and tread on both the truck and trailer.
  • Inspect the hitch, safety chains, and breakaway cable.
  • Confirm that trailer lights and brakes are working properly.
  • Verify you have your roadside assistance contact info and membership ID on hand.
Build a Solid Emergency Kit
Pack essentials to help you stay safe and self-sufficient on the road:
  • Reflective triangles or road flares
  • Flashlight with extra batteries
  • Basic tools and duct tape
  • Spare tire and jack
Know Your Rig
Keep your trailer specs (length, weight, VIN) saved on your phone or printed in your glovebox. You’ll need this information when calling for assistance.
Stay Safe
If you break down, pull off the road as far as safely possible. Turn on your hazard lights, set up safety triangles, and stay clear of traffic while waiting for help.
What Happens During a Roadside Assistance Call?
When something goes wrong on the road, knowing what to expect can ease the stress. Here’s how a fifth wheel roadside assistance call typically unfolds – and how to make the most of it:
  • Call for Help: Call your roadside assistance provider using their dedicated app or emergency number. Be ready to share your exact location, the issue, and your RV details. Let them know if your trailer is hitched or unhitched, if you’re in a remote area, or if you need heavy-duty towing. The more accurate you are, the better they can dispatch the right help.
  • Understand Wait Times: After the call, you’ll receive an estimated arrival time. Delays can happen, especially in rural areas, remote locations, or national parks where service trucks are limited. If your situation requires a heavy-duty tow truck or an RV-trained technician, it may take longer to coordinate and result in longer wait times. Some providers prioritize RVers or send alerts when help is en route.
  • Technician Arrives: Once onsite, the technician will assess the issue and either fix it onsite (for example, change a tire or jump-start your battery) or arrange a tow to the nearest qualified facility. In some cases, you may need a second truck – one for your trailer and one for your tow vehicle.
To ensure a smooth service call, communicate clearly and give as much detail as possible when calling the provider. Stay calm and cooperative while prioritizing your safety. Take photos of any damage or mechanical problem to document the condition of your rig and support any future insurance claims.
Wrapping It Up
Towing a fifth wheel opens up an incredible world of adventure. But it also comes with a higher level of responsibility and risk. Having the right roadside assistance plan ready ensures that if anything unexpected happens, you won’t be stuck Googling solutions or scrambling for help in the middle of nowhere.
To ensure you're fully covered, explore Good Sam’s Platinum, Platinum Complete, and Platinum+ Plans that include fifth wheel towing. They're the trusted companions to keep you moving confidently on the road.
FAQs
1. What is fifth wheel towing assistance?
A: Fifth wheel towing assistance is specialized roadside help designed for fifth wheel RVs. Services often include towing, flat tire help, fuel delivery, lockout support, and more, with certified technicians and equipment suited to large rigs.
2. Do standard auto roadside plans cover fifth wheels?
A: Usually, no. Most standard plans exclude trailers above a certain size or weight. Always read the fine print or go with a dedicated RV roadside assistance provider.
3. Can I use roadside assistance if I’m boondocking or off-grid?
A: Coverage for boondocking or off-grid locations varies by provider. Some plans may offer limited or no service in remote areas, so it’s critical to confirm with your provider beforehand. Providing precise GPS coordinates can help facilitate service if it’s available.
4. How much does RV roadside assistance cost?
A: RV-specific plans can range from $80 to $200+ per year, depending on coverage level. It’s a small price for peace of mind during your big adventures.
5. Is fifth wheel towing assistance worth it?
A: If you travel often with a fifth wheel, it’s absolutely worth it. The right plan means faster, safer help in emergencies, and a lot less stress when the unexpected hits.
